February 2019 Issue
Unairworthy
Wrong nuts.
Whenever a nut is subject to rotation, it is required to have a drilled bolt, castellated nut, and cotter key. In the top photo you can see that the proper bolt/nut combination is correctly used on the forward rudder cable link attachment, but not on the aft one. Similarly, in the bottom photo the nut on the control column, which uses a brass insert as a bushing, requires a castellated nut. If a bolt is used through a rod end bearing, the use of a fiber locknut is approved, as the bushing in the rod end bearing rotates instead of the bolt.
Download File
Photo by Richard VanderMeulen
Old Crow Huber RV-7AAfter six and a half years, I received an airworthiness certificate on August 2, 2018. The first two flights were on August 10, flown by my highly experienced RV friend, Tom Berge. I completed the flight testing in early October. I then flew the aircraft up to Hibbing, MN for a paint job at Midwest …
Video Archive
PO BOX 8535
Big Sandy, TX 75755
